Why is my speaker have flashing lights and no sound?
No sound and lights flashing?
Update (03/12/2016)
I dont know I am having the same problem
这是一个好问题吗?
Device and repair information for the Behringer Eurolive B212D speaker system.
Hi,
Bit confused here. You're stating a wireless microphone. Have you got some sort of wireless equipment connected to either the Behringer Eurolive B212D XLR input or the 3.5mm TRS input connection? If not how is your wireless microphone's output being connected to the input(s) of the speaker?
According to what I can find out the Behringer Eurolive B212D does not have wireless capability.
If you do have some sort of wireless microphone interface equipment connected then I'm assuming that you have got it setup somehow as per the image below. If not and your wireless microphone is 'connected' to another piece of equipment for it to work, check its' connection to the speaker(s) and ensure that it is connected to the appropriate input and setup as per below depending on input connected.
If the microphone? is connected to the XLR input (as shown in the image) set the level adjustment on both the speakers half way between the centre (vertical) position and the maximum position. (turn the selector clockwise).
If the microphone? is connected to the 3.5mm TRS input socket set the level adjustment on both the speakers half way between the centre (vertical) position and the maximum position. (turn the selector anti-clockwise)
By speaking into the microphone, adjust the level adjustment on both of the speakers to get the desired volume. (Also check the output level of the wireless equipment?- if any- to see that it is not set too high). If the clip light comes on (on either speaker) it is too loud and needs to be scaled back until the light goes out. Also adjust the equalizer controls on both speakers to get the desired 'sound'(bass and treble mix).
RE: Teixeira
When you run an amp into clipping, quite often bad things happen. The initial thump is probably because the protection circuit has not completely engaged yet or is somewhat defective. Basically the amp section now needs some work. I would expect to find that the output transistors are shorted. I believe that this unit uses discrete transistors for outputs. This should be a fairly simple repair for an experienced amp repair individual.
Dan
评论:
Hello, on a Behringer EPS500MP3, I have looked into the capacitors and they are fine. Could it be just the IC ? It has same symptoms, POWER LED and LIMITER flashing. You can also ear a "tic tac" noise on the board
由 HGB HGB 完成的
Hey i got exactly this problem, what to do???
由 kommunistisch-nachtleven 完成的
声誉积分: 1
My problem is that all the lights are flashing and no sound, even when all cables are disconected except the power cable.
评论:
Hi,
I'm wondering if there is a power problem. It may be that there is a missing power supply rail in the amp. There are a few different DC voltage rails produced from the AC input
As I cannot find a schematic for your particular model I can only suggest that you visually inspect the circuit boards in the amp to see if there is anything obviously amiss e.g. blown or swollen capacitors or stressed (heat affected - burnt) components. Do this with the power totally disconnected from the amp. Be safety aware!
Here is a link to the schematic diagrams for a Behringer B215D (I realize that this is not your model) which may be close enough to help you.
https://elektrotanya.com/behringer_b215d...
To download the file when the sentence below the Document preview box changes from "This file is downloadable free of charge: ...processing..." to "This file is downloadable free of charge: Get Manual" click on the Get Manual as this is the download link. Be patient it takes a little while to find the file.
由 jayeff 完成的
Just change the capacitor c2 and c7. 47uf 35v. Change to bigger voltage. Check other bloated capacitor.
由 Mohd Fikri 完成的
由 HGB HGB 完成的
声誉积分: 1
声誉积分: 1
I had the same issue with one of my Behringer B115W's. I tried twice to get it repaired under warranty ... Behringer ignored both of my on-line requests.
Because I have two gigs coming up, I decided to fix it myself. I was expecting a "bad Capacitor" issue on the power entry side ... (i.e. symptoms dim pulsing LED's and no sound)....
to my surprise ... all caps looked good.
So I re-seated all connectors and put it all back together and it's started working fine again.
评论:
i have the same problem mike with the same speakers can you please describe to me what it was that you did thanks djloud704@gmail.com
由 David Mccluney 完成的
change the capacitor c2 and c7. mention at board. you can see at mosfet area.
由 Mohd Fikri 完成的
声誉积分: 1
I have a 115D that's doing the same thing, I just removed the amp, even took it out of it's metal case....still flashing, no sound, caps all seem fine, no shorted power transistors and nothing looks burned. Regarding the "wait 2 or 3 hours" it sat for a week before I was given it to repair, I hope there i a factory somewhere this guy can buy an entire amp from, it only sells for $300 and my repair charge will be $200 if I can fix it.,...doesn't seem worthwhile to repair
评论:
Where are you located? This should be a straight forward repair and should be less then $150 to fix (parts and labor).
Dan
由 Abrsvc 完成的
Hi Dan,
I'm in Connecticut, but my point is that I've been fixing this stuff since it was built with tubes because that's all there was, this amp was absurdly difficult to get apart and promises to be !&&* to reassemble...even if I give it back un-repaired.
There appears to be no way to check voltages with it flashing LEDs I have to assume it's in protection, without a schematic and with no shorted or burned components I have little desire to start pulling semiconductors "just to test them"
Have you worked on one of these previously? If so, is there a part that's particularly prone to failure that would throw it into protection ?
If you have any ideas I'm all ears
Have a great weekend
Kevin
由 Kevin 完成的
Contact me offline. It will be easier to continue diagnosis.
由 Abrsvc 完成的
Hey Dan,
I put it back together and wrote an email to Full Compas to see if they could get the amp as a spare part. They list every part of it except the box and the amp, they even sell the preamp/mixer board. They have amps for other models for $99 apparently . I'm done with it but greatly appreciate your interest in helping. Thanks again, Kevin
由 Kevin 完成的
If you do replace the amp block, save the old one. I would be interested in trying to resolve the original problem. If you can figure a way to contact me directly we can arrange to make that happen. I'm not far from Ct (Ma). I can't locate a way to send a private message though...
Dan (I too have been repairing electronics for over 35 years)
由 Abrsvc 完成的
声誉积分: 1
I’ve been having a similar problem with my B212 D. When I turn it on, both lights flash and then turn off instantly. There's also an audible, but low volume, thump from the speakers when it switched on. This equipment was used in very high volumes, started clipping and automatically turned itself off. It happened three times until it eventually crashed on stage.
评论:
If it's the same amp that's in the 115, you can buy the entire block from Full Compass, look on their website, for my customers 115 every single little part was listed except the amp, I emailed them and sure 'nuf, they had it, $150. The 115 looks like an aluminum brick, it's not made to be repaired without dedicated jigs, the pieces fit together like a latex glove, I'd be certain that even the factory tosses them, they would have to pay one of their techs for an hour of work just to rip it down and reassemble it, oh, and fix it too. Not economical. Do yourself a favor and look at Full Compasses web site or email them. They got back to me in a day
由 Kevin 完成的
声誉积分: 1
replace the small capacitors on the primary side that should solve the led flashing issue.
评论:
can you show me the caps that you telling by photo, I think we the same issue
由 alexarriola_42 完成的
Two 47uf 35v. Mention at board. . C2 AND C4.
由 Mohd Fikri 完成的
由 HGB HGB 完成的
声誉积分: 1
I have a problem with my behringer eurolive b115w, it’s the power problem, I just have to wait a minute before power supply get to normal
评论:
No. This will not settle the problem. When the times come. Your board will burn. Please check capacitor c2,c7,i.c 5,c85,c86,c89. Thanks me later
由 Mohd Fikri 完成的
The problem is simple. The capacitor dan the i.c has spoil. Please check and chamge two 47uF 35v and I.C 1271A. Change this will settle the problem. Please check also other bloated capacitor if you see it when you open the amp. I suggest use a glove to protect your hand from CRC COMPOUND. TQ. thanks me later.
评论:
have the same problem no bloated capacitor c2 and c7 look good but i can not find I.C 1271A i have the b115d
由 sandro moreno 完成的
do i still replace them
由 sandro moreno 完成的
I have the same problem with a Behringer Europort EPS500 mps - flashing lights on the front of the mixer and SMD leds D14, 15,16 and 17 on the power supply/amp board. I have removed the main smoothing capacitors (2200 microF 50V). the IC5 on the board is a 7815 voltage regulator. Should I attempt to replace all the voltage regulators as with out a repair manual for this model of power supply/amp its a bit of guess work as there appears to be no bulging capacitors
由 Mitchel Grindrod 完成的
由 HGB HGB 完成的
声誉积分: 1
Hi all,
I can confirm also that replacing 47uF 35V capacitors C2 and C7 fixed the flashing led problem on power up.
I have a B115MP3 unit and all is working fine again.
The original capacitors did not look faulty and measured approx 42 to 45uF but replaced them anyway and problem resolved.
评论:
As I have the Behringer EPS500MP3 I believe my equivalent capacitors are C48 and C49 which are the support capacitors to IC 1271A. I have replaced both of these capacitors and the IC. The fault of this IC was actually a supply resistor which now works! Unfortunately I cannot get the main amplifier IC to work and have damaged another IC (IC 3), fault finding, which I believe is a dual audio op amp 4580R . A real challenge without the circuit diagram!
过去的24小时: 11
过去的7天: 98
过去的30天: 345
总计 23,604
Hi, Which light is flashing, the power light, the clip light or both?
由 jayeff 完成的
Both green lights for wireless mic and power light on channel 2 and clip light on channel 1. And it's not putting out any sound.
由 Cody 完成的
i have turbo sound powered speaker and it has no sound when i connect my device to the input as well as in mic input but when i plug it in the out,thru it has working in the other speaker and i got flash and signal from my mp3 device..thanks for the answer.
由 Ruel Cabarlo 完成的
I have the same problem with the Behringer Europort PPA500
Flashing lights on the front and no power or volume etc…
I have no idea what to change?
people are saying the IC?
can someone clarify?
由 Dan B 完成的
