跳转到主内容
Released on June 23, 1996, Model NUS-001, 64-bit gaming console
New to N64, it turns on but no console noise no picture?
I've recently bought the Japanese orange pikachu N64 and when I turn it on the cheeks flash and then stay on but the console makes no noise and no picture comes through either the rf cable or the rca from my gamecube, any advice?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Thanks, I will try that :)
完成的
添加一条评论
3个答案
You most likely need to clean the cartridge slot. If the N64 can't read the cartridge, it will not display any picture or sound. I usually clean my older cartridge-based Nintendo systems by dipping a qtip in %90 isopropyl alcohol (rubbing alcohol) and then running the qtip along the connector on any N64 game cartridge. Then repeatedly insert and remove the cartridge from the slot on the system. This will clean off any dust or dirt that has built up inside the slot over the years.
这个答案有帮助吗?
得分 0
添加一条评论
not an expert but try to unplug and plug in the AV or RF cable, if it doesn't work, get 3rd party cords, happens all the time to me
这个答案有帮助吗?
得分 0
添加一条评论
I know. You slap the bottom hard 2 times. Then you chuck it at the ground. It should work by then.
Copyright: how to basic
这个答案有帮助吗?
得分 0
1条评论:
Ps.
it actually worked
完成的
添加一条评论
添加你的答案
Tom Jones 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 26
总计 3,730
