Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
If you can receive incoming calls OK have you checked that you have enough credits for your phone or that the bill has been paid? If so is it only one number in particular that you are having trouble with or a particular group of numbers e.g. have you barred 'premium services' numbers from the phone to reduce incurring excessive charges for instance?
If you can't make calls with any sim card but people can call you then you should check your IMEI number to see if it is blocked or not via IMEI.info:
You can view the IMEI view the battery compartment on the white stick behind the phone. You can also view it under the phone settings and on the box if you have it.
Hi,
由 jayeff 完成的
What country are we dealing with as this can be a different answer in a different country
由 Jimfixer 完成的
Did you buy this phone from someone recently?
http://www.imei.info/
由 Ben 完成的
