Device is paired (post-reset) but it wont play any sounds? :(
I reset my device (plus sign with center button). Pair my ipad, but all i hear is a very slight static/hissing/white noisish sound despite the music runnning on the ipad.
Help? :(
Hi,
When you reset the speaker, did you also remember to forget the Air Raid in your Ipad Bluetooth list before you re-paired it with the speaker again?
Try a soft reset again as per the following information and see if it resolves your problem.
Soft Reset:
Hold Volume + and the center button for 5 seconds to reset the paired device list in the speaker.
Remove Air Raid from your device: Go in to pairing settings on the device and remove or ‘forget’ Air Raid.
and then pair again.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 236
