跳转到主内容
The Nexus 6 is an Android phone developed by Google and Motorola released in 2014 with a 6-inch display.
68 个问题 查看全部
Wifi , portable Wi-Fi hotspot and blutooth not switching On
When I try switching on Wi-fi it shows "Turning Wi-Fi on " but it doesn't turn on. Same is the case when I try opening Bluetooth or switching on Portable Wi-Fi hotspot.
I have tried clearing cache partition and even did a factory data reset.
I even turned on to safe mode and tried opening wifi but the problem persists.
The battery also drains quickly on a full charge I usually get around 6 hrs.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Do you still have warranty on this phone? Most likely not as it was released in 2014, this is a hardware issue.
Only thing I think might help is try updating the Android OS if it isn't up to date already. If I'm correct the latest version is Marshmallow.
这个答案有帮助吗?
得分 1
2条评论:
android version is up-to-date , it's 6.0.1 and warranty period is over.
完成的
Is it possible to replace the chip associated with Wi-Fi and Bluetooth.
完成的
添加一条评论
I too have the same issue. Couldn't figure out what triggered this issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
yatish chandra 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 74
