跳转到主内容
The Nexus One (also known as the HTC Passion and Android Dev Phone 3) is a smartphone from Google (manufactured by HTC) that runs the Android operating system.
19 个问题 查看全部
问题已关闭
No sim card problem
Hi all,
My nexus one obstinately refuses to recognize the sim card that I insert in it. It is not sim-locked, as no unlock code is asked. Instead, the usual message appears: "no sim card, emergency calls only". Well, I guess the sim card tray is dead, unless you have other explanations..? There is a good Ifixit tutorial to replace the sim card tray, but I have been unable to find where I could by the part.
Any idea?
Thanks for your help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi, Have you tried the SIM card in another device to see if it works? Have you tried another known working SIM card in your device to see if it works in it?
完成的
Hi jayeff, thanks for your help! Yes I have tried with two Sim card that works with another phone. I also went to a phone store and the result was the same with a genuine sim card.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
Have found these which may be what you are after. You may be able to find more
I am not recommending either seller, either way, just pointing out where there are parts.
p.s Take notice of the positive feedback % of the seller in the second link. Personally I prefer it to be above 99.5% but that's just me.
http://www.ebay.com/itm/SD-Sim-Card-Read...
http://www.ebay.com/itm/Memory-Card-Hold...
Hopefully this is of some help.
这个答案有帮助吗?
得分 2
4条评论:
Thanks a lot! Do you think that the two products are identical, apart of the feedbacks of the sellers? I mean, on the first link the sim reader is provided with kind of a connecting film that is not in the second link. Do you think it has its importance?
完成的
Hi gabstet,
I think that anything that is in the phone is there for a purpose. The makers don't waste money on having unnecessary things installed.
There should already be a connecting film covering the old SIM card tray in your Nexus one. You should be able to re use it for the new one. Also the first link is a 'used' SIM card tray while the second link is 'new'. Being used might mean that there may be issues later on but who can tell. That will be your decision which is the better way to go.
完成的
Allright, once more thank you for your wise advices! I will tell you if if has worked at the end!
完成的
Hi gabstet ,
Good luck
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 707
