跳转到主内容
Laptop released by Dell in 2005, features a 15.4" display and Intel Centrino processor.
21 个问题 查看全部
How do I extend the LCD screen cable?
Hi, my Dell has gotten a bit old and crotchety, and the keyboard has completely broken, so I decided to turn it into a wall mounted tablet, using a tablo pen to create a pseudo-touchscreen. However, I realized quite quickly that the cord connecting the LCD to the motherboard is really really short. Does anyone know what kind of cord this is, and how I can get an extender for it?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
已选择的解决方案
Depending on how ambitious you are, and how sure you are of your soldering skills, I would suggest splicing the wires and soldering the cables anew. Otherwise, you could visit an electronics parts store, try to find a matching adapter and just build an extension yourself.
这个答案有帮助吗?
得分 1
添加一条评论
cyberguys.com
look
http://www.cyberguys.com/product-search/...
Update
yes you can..
I bought 10 cables with a splitter
这个答案有帮助吗?
得分 1
添加一条评论
I don't think you can do that.
This guide can be helpful:
How to replace damaged LCD screen in Dell Inspiron 6000 laptop
这个答案有帮助吗?
得分 0
添加一条评论
First of all, what is a "tablo-pen" to create a pseudo-touchscreen?
As to answer your question, it is likely the best to add enough lenghts of wire to each braid to meet your demand. I do not know if you can buy extention cable for it, however, if you've got skills just do it! It's the best way to circumvent problems. Mine is getting old but still runs well; got the first battery replaced a couple of years ago, for a staggering £15.00, that is 7200ma instead of 4800 like the original was. And was forced to buy a knew 150bg HDD little over a year ago, after I had accidentaly approached the keyboard with a speaker magnet. It is a lot faster to boot up now but, sadly, failed to back up anything prior to it, hence lost everything that wasn't backed up by fluke.
这个答案有帮助吗?
得分 0
添加一条评论
You probably wont get an extension cable for such internal types. The best way is to use an external VGA cable which cost so less and get a external monitor to attach with it.
If you are that techi then you can extend this cable by yourself using a similar wire loom to extend each cable one by one.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 23
总计 7,887
