跳转到主内容
An android smartphone released by BLU Products in December 2013.
Why is my phone not detecting the SIM card?
Whenever I try to make a call or send a text message, my phone says "No SIM card is detected", but the SIM card is installed. Why?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
i'm trying to make a call and it says turn sim on and when i do it doesn't do anything
完成的
添加一条评论
2个答案
已选择的解决方案
This might be a problem with the SIM card itself. In order to fix this problem, the SIM card will have to be replaced. If replacing the SIM card is still not working, then it is most likely the problem is within the motherboard. In this case, the motherboard will have to be replaced. Visit the troubleshooting page for additional information and links to respective replacement guides.
这个答案有帮助吗?
得分 4
4条评论:
If it's not the sim card, try resetting your phone to factory reset before spending time and money on motherboard repair or replacement. Could have saved me a lot of money and time if anyone told me.
完成的
My Sims card want work
完成的
My BLU phone has two sim card ports. The sim card wasn't working in the top one. I turned over the sim card (gold part now facing up) and put it in the bottom tray( you have to slide out the metal pull thing) place it in the tray and slide it back in. After hours with PureTalk tech support, I figured it out myself.
完成的
It's actually pretty easy to fix and you don't need to buy anything.
I opened up my girlfriends; took the battery out, then the sim card out and put them right back in.
How to take the battery out, look closely to the screen and backing. Look for a little (dip or notch) pull the phone apart literally and it'll open. Look it up on "YouTube.com" I hope that helps!
It now works right after. Remember to then turn you phone on.
You could also turn off your phone and turn it back on and see if it works.
完成的
添加一条评论
What to do if resetting the phone does not work??
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Daniel Kelly 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 27
总计 50,129
