跳转到主内容
Identified by the FCC ID 2ADCW-PLUS. Released in December 2014
Why Can't I Charge My Wireless Speaker Using USB Cable?
I have a wireless OontZ Angle Plus speaker. Speaker's battery is depleted of power and will not receive a charge when connected to a power supply via USB cable.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
When using your Oontz Angle Plus and you discover the device will not charge it is possible that the battery needs to be replaced after regular wear and tear. Therefore, you must disassemble the device and replace the battery using the troubleshooting page listed below.
There is also the possibility that the wire connecting the batteries have become loose and are not connecting properly. You will also disassemble the device and reattach the wires using the troubleshooting page.
Cambridge SoundWorks OontZ Angle Plus Troubleshooting
这个答案有帮助吗?
得分 2
1条评论:
Thank you Matthew
完成的
添加一条评论
I only had my OontZ 3 plus for 3 weeks and both my speakers will not charge up at all! This has to be defect!!
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem a few weeks ago and contacted Oontz and they sent me a replacement. I’ve only had this replacement for a handful of days and it’s happened again.
I don’t know.
Despite all the good reviews on the quality/fidelity of the speakers, this is a joke.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Farshad Mohebban 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 8,541
