跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Phone dies at 20%
I recently got a used iPhone 5s from my aunt. It is running iOS 9.2.1 and everything works fine exept for the fact that the phone will die with 27%, 25%, or 20%. When I plug it back in to charge the phone turns on again with the same battery percentage as it had when it died. Is this a software or calibration issue or do I need to replace the battery?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
i had same issue with my 2 years old phone, at 30% it will totally shut down, what i did is i replaced the battery, now everything is perfect. i used the ifixit battery replacement kit
这个答案有帮助吗?
得分 1
添加一条评论
I would try putting the phone in DFU mode and updating/restoring it.
Let the phone die and then charge to full
If it happens again the battery needs replacing
这个答案有帮助吗?
得分 0
添加一条评论
Usually happens when you don’t charge your phone often or the common one, the battery may be old or not working. You can charge it to full and kill it again over and over til it works.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vince Parisi 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 13
总计 5,754
