跳转到主内容
AT&T Corded Answering System with speaker phone, audio assist, digital backlit display, and caller ID/call waiting.
Why is my device not recording any messages?
When I miss a call, the device will not record or save any of the messages people leave. What should I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
can not get the message recorder to record a message when phone rings can not set up
完成的
what is the long press screen? I have no msg’s and says I have 49 missed calls but my memory is full, no one can leave a msg, how can I delete those?
完成的
添加一条评论
2个答案
已选择的解决方案
Make sure the answering system is on. ANS ON light on the telephone should be on. Make sure the memory of the answering system is not full. If there is a fax machine connected to the same telephone line, try disconnecting the fax machine. If that
solves the problem, consult your fax machine documentation for information on compatibility with answering systems
这个答案有帮助吗?
得分 2
添加一条评论
Hi @wgerome ,
If you have an AT&T CL4940 telephone, (you didn’t specify the make or model) here’s the user manual.
Go to p.40 to view how to delete the old messages from the phone’s answering system.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Nigel Mathias 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 31
总计 1,514
