跳转到主内容
6.1 megapixels, ISO 200-1600, DX format, 1.5x field of view crop
Where can I find purchase the CCD Sensor part
Anyone know where I can get the CCD Sensor replacement part?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
Nikon will not sell it to you as their policy is not to sell internal parts. The only alternative is to buy a used/broken camera and salvage it, or buy it from reseller on eBay. E.g. similar to this.
这个答案有帮助吗?
得分 2
1条评论:
Link no longer works
完成的
添加一条评论
Your best bet is to nail down the CCD Sensor model #, chances are Kodak may have manufactured it. Kodak & Nikon have become once again independent in the Digital Replaceable Cameras Age since they are finally making $$$$$ once again. You will be lucky if they answer your emails, although if you know exactly which CCD Sensor it is the odds could be better than average that you could pick up a cracked point & shoot camera for $10.00 with the exact same CCD Sensor in mint condition in the camera. You need to do the research on the specs of your Sensor & find out which other Digital Cameras have the same one. Just another avenue to take, hopefully this helps you, Good luck.
这个答案有帮助吗?
得分 2
1条评论:
Update: Kodak as they were in 2010 are long gone. They did once have a relationship with Nikon but that was gone even then. CCD sensors for consumer grade cameras are not widely available as spares and transplant from a donor camera is the best option.
完成的
添加一条评论
Nikon have had a long relationship with Sony for the manufacture of sensors. These days the Nikon marketing blurb generally says 'developed by Nikon' for all the new devices. I used to work for Kodak in the early days (circa 1996-2000) when there was a link between Kodak and Nikon, but to my knowledge that relationship is long gone.
I would echo the advice of Daniel. Find a used body with a functional sensor and make the replacement by transplant. Taking apart the donor camera will also give you useful experience for the later disassembly of your original body.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Matt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 10,652
