跳转到主内容
在2015年3月发布,于2015年4月10日开放购买,Galaxy S6 Edge是Samsung最新的旗舰智能手机的曲面屏幕版。
237 个问题 查看全部
Repaired from water damage, replaced battery, several issues.
Hey there, I recently recovered my phone from heavy water damage. Cleaned the whole inside with isopropyl, and had to replace my battery due to being saturated in water. I replaced it with BG920ABE (i believe i'll have to double check) which was abit different from my original battery model. So my phone worked for awhile pretty well, except my normal incall microphone was abit soft and my gyroscope and a few other sensors of the phone didn't work, (like gps navigation direction, heartbeat sensor, screen orientation). My current issue now is when i charge my phone with the original charger, its starting to have battery drain issues, it switches to a fast drain, then when i turn it on again it goes back to the ACTUAL battery percentage. Its as if its having trouble determining the battery life and as of right now the phones not turning on. I would like to know how i can repair the sensors and if i should replace my battery again with the actual model. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
I have a s6 edge 925t recovered from water damage with similar problems, It seems to discharge quickly even when powered off. Replaced bat. I noticed a lot of corrosion around the battery connector on the motherboard, and cleaned as best I could with ipa, ultrasonic cleaner, and tried reflowing the connectors in the area.
You really need to get out the microscope or magnifying lens with light and look over the whole board closely to see any possible bridged connections or loose connections. Also check the pins on the flex cables and connectors.
Mine worked fine for awhile but now back to discharging the battery when powered off. any input appreciated
这个答案有帮助吗?
得分 1
2条评论:
You might want to try an oem battery as well, these things seem finicky
完成的
might i ask what ultrasonic cleaner did you use? im looking at purchasing one myself, mainly for phones. Thanks!
完成的
添加一条评论
water damage is very tricky, you might consider a cleaning solution versus alcohol, also if it was salt water warm water mixed the the highest percentage alcohol works well. but i would also agree on replacing the battery with a oem battery and removing all service panels on mother board to access all of the board that could be water logged still.
这个答案有帮助吗?
得分 1
1条评论:
also if you go on ebay for u.c. they china made ones by xao work very well in my past experiences
完成的
添加一条评论
添加你的答案
James 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,113
