跳转到主内容
A basic battery-powered rotary tool Manufactured in 2007 by Dremel.
Why won't the Dremel won't turn on?
I know it is charged and I am flicking the on/off switch but no noise or anything. What is wrong?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
How do you know its charged? Did you test the battery with a load test? Its possible the battery is dead. eventually all batteries lose the ability to be recharged.
完成的
添加一条评论
2个答案
已选择的解决方案
While you were charging the battery, did you see the LED light blinking? If it was is blinking, that means it's charging. If it was blinking and it is still not turning on, there is the possibility of it simply being worn out. Please refer to the Troubleshooting page or the battery repair guide
这个答案有帮助吗?
得分 1
添加一条评论
Also, if the LED does not come on at all, the charger may have gone bad. The chargers for the 7300 should not be left plugged in "forever".
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kat 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 36
总计 11,392
