跳转到主内容
Portable wireless speaker with a built in microphone. Released January 27th, 2014.
Why is my device not charging?
I connect my device to the USB cable and never charges unless I hold the cable.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
6个答案
最有帮助的答案
Hi Daniel,
This problem sounds like you have a faulty MicroUSB port on your Flip 2. On occasion, the Flip 2's MicroUSB port may become dislodged, causing issues in charging or connectivity. You can try soldering the MicroUSB port back onto the circuit board. You can visit our guide here for more information on the repair of the port.
这个答案有帮助吗?
得分 3
添加一条评论
it sounds like the charge port is broken if it needs to be in a certain position to work
这个答案有帮助吗?
得分 1
添加一条评论
I charge my flip 2 & it doesn't charge.
Update (04/27/2017)
Yes I have to position it a certain way but still don't get full charge & how much would it cost me to get this repaired and where can I go.
这个答案有帮助吗?
得分 0
2条评论:
Hi Veronica,
Did you solve the problem already and if yes, diy or specialist repair? I have the same problem.
Erwin
完成的
I am experiencing the same problem with my speaker in that it wont charge. If you fiddle with the cable the lights will flash briefly and then goes off. How can this be fixed as I like the quality of the speaker. Assistsnce will be appreciated.
完成的
添加一条评论
JBL speaker charging soket damage
这个答案有帮助吗?
得分 0
添加一条评论
I have had that problem over the past decade with various Bluetooth speakers & headphones that require recharging. I find that the manufacture of the recharge ports and cords is anything but standard. By hanging onto every charger cord I get with products and any that someone has thrown away (and buying a few for less than $10), I usually find a charger that will work for any particular item.
这个答案有帮助吗?
得分 0
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daniel Anzola Delgado 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 3,825
