跳转到主内容
加入维修社区 - 创建账户
Introduced November 2012, this is a capable desktop computer with an Intel Core i7 3770S quad-core processor, 12GB of RAM, and a 3TB hard drive. It has a 23 inch, 1080p touchscreen and integrated Beats Audio.
Why is my computer not turning on?
My computer is not turning on the a/c adapter makes a noise and light blinks but the monitor will not power on I have purchased a new a/c adapter thinking it would resolve this issue and that did not fix the problem any ideas of what I can do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Computer ENVY 23 not turning on blank screen ! HELP
完成的
添加一条评论
1个答案
已选择的解决方案
Is there a hdmi port or a dvi or vga that you can hook it up to an external monitor to see if it will work that way ? this will tell if the screen itself is the problem . You may also want to try removing one stick of ram at a time to see if the issue is with the ram.
HP Envy 23-d060qd TouchSmart RAM Replacement
You could also try doing a static discharge. Unplug the computer and then hold the power button down for 60 seconds then plug it in and try to boot
. Hope some of this is helpful
这个答案有帮助吗?
得分 2
1条评论:
Yes, the static discharge option works with this type of machines.
完成的
添加一条评论
添加你的答案
Anayeli 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 24
总计 7,313
