跳转到主内容
Repair guides and troubleshooting support for Leapfrog LeapPad3 Learning Tablet
My speaker and D-Pad are simultaneously not working.
The speaker is fuzzy and sometimes does not have any sound at all. Only one or two of the directions on the D-pad are registering. I'm looking for a way to resolve the issue without replacing either component.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
My Leappad won't let me press my name on my Leappad.
完成的
添加一条评论
1个答案
I had the same problem with my LeapPad3. Always turn off your device and turn it back on again, as this can solve a few issues your device is having. If this doesn't work, you will have to remove the back cover of the device and tighten the cable connecting the speaker to the motherboard. If that doesn't fix the problem, then you may be forced to replacing the speaker itself. There is a guide 'here' that can help you through the process step-by-step. Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Matt Irvine 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 336
