跳转到主内容
Repair guides and troubleshooting support for Leapfrog LeapPad3 Learning Tablet
10 个问题 查看全部
How do I reset my LeapPad?
My LeapPad froze and it won't turn on or off. Is there a way to hard restart it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
3个答案
已选择的解决方案
If turning the device off and on does not reset your device properly you may need to preform a computer reset. In order to do this you must download Leapfrog connect to your computer. Then, put your device in "connection needed mode" by holding down the right D-pad button and the home button while simultaneously turning on the device. Than, plug the LeapPad into the computer and it should begin to sync. Once the LeapPad syncs to the computer, it should boot up normally.
这个答案有帮助吗?
得分 6
1条评论:
Not sure yet. I'm going to have my daughter do it when she gets here. Hopefully I can get back to you and let you know if this works.
Thank you
完成的
添加一条评论
Are all the leapPad connect downloads the same....They show one for every model.....After I download the app ...the tablet does not connect to my computer....The image shows it's connected to the computer by the cable....but I can't find where I can get anything done with it...I'd like to factory reset..
这个答案有帮助吗?
得分 0
添加一条评论
I forgot the four digit parental code, how do I retrieve the password, or is it possible to reset the password?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Matt Machmuller 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 63
总计 35,982
