跳转到主内容
加入维修社区 - 创建账户
An audio/video receiver (AVR or home audio receiver) is a consumer electronics component used in home theaters that convert signals into sound.
Wondering if it's a bad relay switch...?
found a tx-v940 at goodwill. same problem - no power to speakers. Did randomly come on at times, but when powered off then on again, there's nothing at the speakers again. Also a series of clicking noises, like some component is powering on/off. Wondering if it's a bad relay switch....?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi Rich Plotner,
Receivers usually use relays to provide speaker protection in the case of a fault on the output of a channel (also used to prevent the speakers from catching fire if due to a fault there was excessive current flow to the speaker). it sounds like one or more are operating.
Here is a link to the service manual for a Onkyo TX-V940. It has all the information, e.g. circuit diagrams etc, to help you to find the problem.
http://diagramas.diagramasde.com/audio/O...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rich Plotner 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,403
