跳转到主内容
加入维修社区 - 创建账户
Nintendo 64 于 1996 年 6 月 23 日发布,型号为 NUS-001。它是任天堂的第一款 64 位游戏主机,也是在 Switch 发布之前唯一的 64 位游戏主机(GameCube、Wii 和 Wii U 虽然可以进行 64 位浮点运算,但并非真正的 64 位架构)。
No video- not cable or connections.
So, not the common (cable) video issue with an NTSC version-
With all my games I have audio, but no video. The TV screen will go black when the unit is powered on and I get the audio from the game booting up. I know the cable is fine because it works on my buddy's Game Cube.
I've opened the unit up and used a point file (didn't have any isopropyl laying around at the time) on all the contacts- expansion pack, game slot, power connector and a/v connector. Also done the same with the contacts on the expansion pack and a few of the games.
just kinda wondering what my next steps are...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
4个答案
已选择的解决方案
You can try a stepwise protocol, its worked for me in the past for reasons unknown. First, take everything out: controllers, game, and jumper/expansion pack. Power it on for about 10 seconds and turn off. Add the jumper/expansion and turn on for about 10 seconds. Then add the game and power on for 10 seconds, then try to actually play something. For some reason its worked for me in the past, but I had both video and audio issues. Worth a shot.
这个答案有帮助吗?
得分 5
5条评论:
I was having the same problem... BWest you saved me!
完成的
This worked for me too. I had no signal whatsoever, performed these steps and it worked perfectly. Thank you so much BWest.
完成的
I had the same issue and your solution fixed it. Amazing. Thanks
完成的
It sucks. It chucked it as hard as I could and it actually worked
完成的
I had a unti that powered on but no video/audio. After removing jumper pack and running it for 10 seconds and reinserting it it worked but after turning off and on again the error came back.
It's a temporary solution and takes only few seconds but would still like to know what to do to permanently fix the issue.
完成的
添加一条评论
This worked for me as well..Thank you for the post..!!
这个答案有帮助吗?
得分 1
添加一条评论
I had a weird black+white only issue and this fixed it! Thank you!
这个答案有帮助吗?
得分 0
添加一条评论
It turns out that following bwests steps, you fry the cpu on the unit
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Wombler 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 16
总计 23,355
