跳转到主内容
The Ryobi P202 part of the Ryobi One+ series. This model is an 18-volt cordless 1/2 inch drill, and is bright green and grey in color. It has a built in level gauge and a two gear ratio switch on the top of the drill, along with a direction switch, magnetic tray, and drill bit clip.
Drill will run for only a few seconds
When you pull the trigger the drill only runs a short time and stops. Releasing the trigger and re-pulling it does nothing. If you release the trigger and switch direction, then pull the trigger it run but again only for a few seconds.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
Hi I have the same problem.I'm thinking bushes.I'll look later and let u know bro
完成的
添加一条评论
2个答案
已选择的解决方案
Battery is most likely dead. Try charging it,........ . Test it using a multimeter. The batteries can go bad and they will no longer accept a charge.
这个答案有帮助吗?
得分 1
4条评论:
The battery can be easily tested using a multimeter ,check voltage before charging, then fully charge the battery , then check to see if it has correct voltage after charging,
完成的
This is not very helpful ,the batteries are fully charged and the batteries work fine in other Ryobi tools.
完成的
Mark Day, yeah i absolutely right with you ,
My problem is with a cordless drill 18V ..
Its worked for a few seconds atleast 3 or 5 second then become off but the battery are fully fine
完成的
I have the same problem with my 7.25" circular saw, my drill and router. All having the same issue, with new batteries. Seems Ryobi tools start dying after about 4-5 years.
完成的
添加一条评论
I did find if you unplug the battery, you reset the thermal protection, and it will run for a bit longer but still shuts down. Once it heats up you need to let it cool down for 5 minutes or so.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Paul Moad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 35
总计 10,898
