跳转到主内容
The Sony Handycam HDR-CX380 was released January 2013 and is identified by the model name HDR-CX380, HDR-CX380/B, HDRCX380, HDRCX380/B, or HDRCX380BBDL.
4 个问题 查看全部
Why won’t my camera focus?
Even though I am taking pictures in a well-lit area, I still can't get the camera to focus on the subject. I made sure that the autofocus was set to on and tried taking the pictures from various distances.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
How much is this going to cost me?
完成的
添加一条评论
2个答案
已选择的解决方案
The problem is likely an issue with the lens. The lens may be damaged or dirty. In order to clean the lens, you will need a lens cleaning solution and a lens tissue. Simply apply a few drops of the solution to the cloth and then gently rub the lens with it. This should remove any dirt, fingerprints, or grime. If that doesn’t help, you can try rebooting the camera by turning it off, removing the battery for about 6 seconds, and then reinserting the battery and turning it back on. If you are still having difficulty, and if the lens has visible damage, you will need to replace it. For more information, take a look at the troubleshooting page for the camera.
这个答案有帮助吗?
得分 1
添加一条评论
It won't focus. The focus indicater stays in middle or moves to left only.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Santoro 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 27
总计 5,610
