跳转到主内容
Display Problem and external display goes black during boot
While trying to replace the keyboard on a MacBook Pro 13 A1278, I might have done something to display.
The system boots up with no display. I hooked up an external monitor via mini display to vga cable and a usb keyboard since the new keyboard I installed is playing up (one column of keys i.e v f r 4 does not work). With external display I get apple logo and the loading bar but half way through back to dreaded black screen.
I have tried every tip I found on the internet. From many many NVRAM resets to trying to boot into safe mode and as well as single user mode.
  • Safe mode is unsuccessful since like normal boot half way through booting up external display goes black.
  • On single user mode I get the command prompt fine. But existing from it means back to black screen.
I have managed to back up the data and attempted to factory restore via internet but again somewhere along the way during installation I lose the display and back to square one.
I even tried booting Linux Mint via USB, but unfortunately same result, half through installation I lose the display.
One occasion I did manage to get to the login screen on external display, but rushed a bit and removed the external display cable without login in first which resulted in black screen on external display when reconnected the cable.
Getting to the login screen once gave me some hope that GPU on logic board is fine and it could only be display problem. The dilemma I have now is no matter what I do, it goes back to black screen on external display half way through booting.
I was wondering if anyone can give me a tip or two to figure out if the problem is with the logic board despite booting up and external keyboard working and sometime I do get the voice over assistance coming up which itself is pain not being able to turn it off without display.
I don't mind changing the logic board or display if I can isolate the problem but not both since that would a very expensive exercise.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Can you give us some background here why you replaced the keyboard in the first place. Also, where did find the replacement.
完成的
The reason to replace the keyboard was, coffee spill ruining the shift key of the original keyboard. I got the new keyboard from ebay.
完成的
添加一条评论
1个答案
已选择的解决方案
I would go over your logic board again as it likely still has coffee on it. Take the logic board completely out and then wash it down with distilled water using a soft toothbrush to scrub carefully any visible damage. Just be careful you don't pull any of the small components off the board. Then go over the board again this time with high quality of isopropyl alcohol (85% or better). This will remove any oils and act as a dryer for the water. Let the board sit on a warm window sill for a good day or two to finish drying it.
Hopefully that does it. If not its time for a new logic board.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
salim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 487
