跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
iPhone 5S Charging Problem
Hello,
I replaced the battery from an Iphone 5S with an new one from ebay, afterwards the loudspeaker was dead. Replaced loudspeaker and lightning port unit with a new one. Speaker is working again, but battery won't charge anymore. Little lightning symbol in the upper corner indicates battery is charging, but even after hours on cable, battery is losing power instead of charging. Installed the old dock connector unit, Iphone is charging again, but loudspeaker is dead.
Any help would be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
You have a faulty dock flex, which is common with ebay parts. You will have to get another. i suggest getting one from ifixit :)
这个答案有帮助吗?
得分 1
添加一条评论
Hello,
I have the same problem except I bought the battery here.
这个答案有帮助吗?
得分 0
添加一条评论
common on the Five S if you have a known working dock, battery and good charger is what is called the tristar IC chip -this regulates charging-
Microsoldering.com, Ipad rehab are 2 places to start for this repair.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
matt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 302
