跳转到主内容
Asus ZenFone 2 (ZE551ML) is an Android smartphone manufactured by ASUS released March 2015.
Why is my phone so slow?
Whenever I play Candy Crush I find that my phone functions very slowly. This is especially apparent when I leave Candy Crush in the background and navigate to other applications. What can I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
已选择的解决方案
The most likely reason that you are experiencing this lagging is because this phone can be operated using different modes. This phone has four different operating modes: Performance Mode, Balance Mode, Smart-saving Mode, and Ultra-saving Mode. Make sure that when you are playing games, you play them on Performance Mode so the game can run more smoothly. Now, be aware that Performance Mode uses the most power, so I recommend making sure that you don't play too long, because then your phone will die: or play with your phone while it's charging.
Although the Performance Mode will help with the performance of game play, the lagging can be helped by simply closing programs and not letting them run in the background when you are done with them. By doing this, you will reduce the possibility of lagging on your phone.
这个答案有帮助吗?
得分 8
1条评论:
This was driving my wife crazy. She would miss a lot of phone calls just because the answer slider wasn't responsive enough. Checked into the "Power management" option , then in "Power saver" and she was on "Super Saving" mode. Switched it to "Performance". No more problem. Thank you!
完成的
添加一条评论
添加你的答案
Sterling Price 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 27,183
