My Wii u gamepad won't stay on
I replaced the screen and digitizer in my Wii u gamepad but a broke on of the little tiny clamps could this be the reason my Wii u gamepad will not come on and stay on
YES! If the flex cables do not connect properly then the pad shows the blue light for a few seconds then turns off.
I fixed this issue using white tak to hold down the tiny little flex cables.
Just push the flex cable onto the connector exactly in line..then use a small blob of tak to hold it down!
Not the best fix but much easier than trying to solder anything!
Try it! it might take a couple of goes to get it right... keep trying and your pad should work eventually.
Hope it helps!
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 322
