跳转到主内容
Won't run on known GOOD batteries. Works only on AC
Hi, I have 2 G4 15" 1.67ghz low res laptops. One runs fine and charges and runs on both batteries. The "bad" laptop will ONLY work if it is plugged in, even if one of the good batteries is used. I've tried all the usual things like pram/pmu resets etc but nothing works. The bad laptop also fails to charge either of the batteries although it does"RECOGNIZE" the good batteries in System Profiler.
Does this mean a bad DC & SOUND card is the problem or is there something else that could be at fault?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
最有帮助的答案
I would replace the battery connector. Here's how: PowerBook G4 Aluminum 15" 1.5-1.67 GHz Battery Connector Replacement
Apple part # 922-6010 Here: [关联产品丢失或禁用: IF154-067]
also the DC cable:
[关联产品丢失或禁用: IF154-024]
这个答案有帮助吗?
得分 2
1条评论:
完成的
添加一条评论
Thank you so much. I appreciate your help. I was told at another site that it was the logic board, but I had my doubts. I've relied on this site for instructions on how to replace the logic board on another powerbook and now I realize I should come here for advice as well!
这个答案有帮助吗?
得分 0
1条评论:
You accepted your comment not the answer.
完成的
添加一条评论
I would like to change your laptop battery can replace it? How to be a kind of operation?
LG Latop Battery
这个答案有帮助吗?
得分 0
添加一条评论
I am sorry, I don't understand your response/question Chinby. Can you try saying it a different way. If you are suggesting I should replace the batteries that is not correct. The batteries are good.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
curtispsf 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 6
总计 1,046
