跳转到主内容
1080p High Definition action camera with 1.5 inch LCD, waterproof case, with a helmet and bike mount.
3 个问题 查看全部
Why is there no sound when I make a video?
When I play my recorded videos, I can never hear any feedback.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
已选择的解决方案
Hi,
1. On playback, have you ensured that the Volume is turned up?
This shows how to adjust (step 5) and where to check on the screen (See #9 on picture)
2. Have you ensured that the microphone is not covered? This shows its' location.
(click on images)
这个答案有帮助吗?
得分 4
添加一条评论
If you have the waterproof case on, you more than likely won't be able to hear any sound since sound can't get to the microphone. Boo.
If you have the case off and still cannot hear anything, please make sure you have the volume turned up on the playback mode!
这个答案有帮助吗?
得分 2
2条评论:
wont work help me!!!
完成的
It’s not working
完成的
添加一条评论
Mine worked with the case. When I tried again without the case I had no sound. I discovered that the voice record has to be off ( x through the mic symbol) . Now it's working again 😁
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
CecilB75 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 16
总计 9,756
