跳转到主内容
The Samsung Galaxy J1, released January 2015, model number SM-J100VPP/SM-J100H.
107 个问题 查看全部
Why does my samsunggalaxy j1 is not opening?
When i tryed starting up my samsung galaxy j1, it doesn't start up until the point that i can use it .. it is stucked at a samsung logo on my screen and keeps on repeating until my battery is dead. Before this happend, my phone says it lacks free storage and can't recieve more msgs. Then i restarted my phone and then this happened. Please help me guys. Really need my phone to be fixed as soon as possible
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 24
9条评论
it will delete all my data stored in internal storage
please add solution if any alternative
完成的
My phone is not starting
Its only showing galaxy J1 ace and turning off it continues like this until remove the battery
It has been charge too but still the samething
Anyone can suggest what can be done
完成的
i tries the hard corde 2 times but it won't let me use it at all ? why it keeps showing verizon get ready to enjoy/ Then iat the bottom it says lets get started emergency call and don't activate?
完成的
Please he LP me my Samsung Galaxy j1 is not working how to restore firmware...
完成的
My sumsung j1 do the same just shows log then went off again and again
完成的
显示更多的4条评论
添加一条评论
4个答案
已选择的解决方案
Samsung logo then off and does it again?
Try leaving it on charge for half an hour if that does not work you may need to do a factory reset or reload the software on the phone in order to get it working again.
To factory reset:
Hold power button + volume up + home button until Samsung logo appears. When Samsung logo appears stop holding the power button but continue holding the other buttons. Once you get into a recovery menu which usually release all keys.
Use volume keys to navigate the menu and the power / home key to select the highlighted option.
Do wipe data / factory reset. Wait for this to complete and reboot phone.
If this still doesn't solve the problem then you will need to restore firmware using Samsung Kies / Samsung Smart Switch.
Or flashing firmware via Odin via this guide:
http://updato.com/how-to/how-to-install-...
这个答案有帮助吗?
得分 9
11条评论:
how to restore firmware using samsung kies?
完成的
how am i able tp restore the firmware on my phone(samsung galaxy j1 ace)
完成的
,how to restore the firmware using my phone Samsung Galaxy J1
完成的
What if after factory reset, it still doesn't work?
完成的
Sir how to repair my samsung j100 its stack showing the logo samsung and it wont even start stack at showing the logo
完成的
显示更多的6条评论
添加一条评论
i try this Hold power button + volume up + home button but it doesn't work, how to restore firmware using samsung kies?
这个答案有帮助吗?
得分 2
4条评论:
It's still it doesn't work to open my galaxy j1
完成的
Please help me to open my galaxy j1... thank u
完成的
Sir can u help me my Samsung j100 dead boot from logo until i restore finish not flushing need fix ty
完成的
Can I buy board of Samsung j100
完成的
添加一条评论
Try to establish a healthy charging regimen so that your battery doesn't learn to die.
这个答案有帮助吗?
得分 0
添加一条评论
My screen still shows “SAMSUNG” and won’t even turn off
这个答案有帮助吗?
得分 0
1条评论:
Need my phone urgently because of health problems
完成的
添加一条评论
添加你的答案
Ac 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 55
总计 56,926
