跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
What is my Logic board reference number?
Following damage to my macbook (13-inch late 2009)
2.26GHz Intel Core 2 Duo
8GB 1067MHz DDR3
NVIDIA GeForce 9400M 256 MB
Serial number: W90054828PW
I have decided to replace the logic board with a 2nd hand one. However, there seem to be two reference numbers for the same model computer:
1) 820-2567-A 661-5395
2) 820-2883-A P7550
Will they both be compatible with my computer?
Is there likely to be much difference?
How do I find the reference number of my original?
Any comments gratefully received. Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
If you look on the edge of the logic board you should find the board ID number. If you stay with the 2.26 GHz board you should get the Rev2 board. You can find a used 2.26 GHz for about $70 US and the 2.4 GHz for $80 US.
2.26 GHz
Rev1
  • Logic Board ID - 820-2567-A
  • Apple P/N - 661-5589
Rev2 >> Current Board <<
  • Logic Board ID - 820-2883-A
2.4 GHz
  • Logic Board ID - 820-2877-A
  • Apple P/N - 661-5640
这个答案有帮助吗?
得分 1
1条评论:
Hello,
please let me know - did the newer version worked? I have similar problem. But Im not sure if Rev 2 on the board will work - my SN: w8005er18pw, emc: 2350, board 820-2567-A (I searched and believe it is 661-5395). Please help me and send some more info to my email: pavel.doschko@gmail.com - Can I buy a rev 2 (661-5589) ? Is it fully compatible?
完成的
添加一条评论
添加你的答案
Simon G 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 282
