跳转到主内容
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
487 个问题 查看全部
My Phone Restarts within 30 sec of turning it on.
my phone is restarting every 30 sec or so, i need to factory reset it to see if that would help. but before i do that i need to get all the pictures off the device.
any suggestions?
sadly 30 sec isn't enough to download all the pictures :/
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Does the phone get into the main menu at least?
Can you boot into safe mode? Hold the power button until the power options appear, then hold the "power off" icon for a few seconds until a reboot into safe mode option appears.
Did you ever connect a google account to the phone?
这个答案有帮助吗?
得分 0
添加一条评论
I have seen this on several s6 g920v (verizon) and g920p (sprint). In my experience update or reflash stock rom using odin does not solve the problem. In my case, several, but not all were after water damage.
first step is to boot into recovery and try clear cache partition, that will not delete your photos, and may do the trick.
You could try downloading the stock rom (make sure you get the same version you are on currently such as og7 ok9 etc)
extracting the files from the md5, and using tar-Tool_Odin3-v3.07_by_mkh.mourad to make just the boot.img file into a flashable .md5 file, and flashing that under the bl tab using the newest version of odin. I
I believe it is most likely a hardware problem, Any input greatly appreciated on where to check on the motherboard for physical damage that would cause to s6 to boot loop would be greatly appreciated
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
serge shust 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 970
