跳转到主内容
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 个问题 查看全部
Keyboard glitches out and trackpad doesn't work
Hi,
I am having some issues with my MBPr, The trackpad all of a sudden stopped working and the keyboard glitches out. I restored the computer to factory default, it did not help. Is the issue most likely the keyboard connector and trackpad connector disconnected or could it be that the whole top case was ruined somehow?
Thanks,
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Check it for a swollen battery.
这个答案有帮助吗?
得分 4
2条评论:
And you tell me to explain the problem even more and put links and stuff yet look at your answer
完成的
The irony here makes me smirk. :)
完成的
添加一条评论
Expanding on @Mayer's answer, there's a valid chance that it's a swollen battery, or a faulty Trackpad.
CoconutBattery 3.3 is the current version, and it's a good tool for assessing battery problems.
http://www.coconut-flavour.com/coconutba...
iFixit's Guide to 2014 Retina Battery Removal:
MacBook Pro 13" Retina 显示屏 2014年中期 电池更换
First, use that program and see if "Service battery" or anything other than Good is listed. Design Capacity should be high, too.
Second, as a diagnostic, open your retina and loosen the battery screws as much as you can, relieving any pressure from a swollen battery, and see if the trackpad gains some sanity. If it does, time for a new battery. If it doesn't, it's a trackpad.
这个答案有帮助吗?
得分 2
2条评论:
Obviously I'm going to have to do a guide on how to get this battery out in a quarter of the time the iFixit staff does it.
完成的
that's why we're here, right? :D
PS, I voted your answer as helpful; though short, it was the best concept.
完成的
添加一条评论
添加你的答案
Masoud Harati 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 393
