跳转到主内容
Motorola在被Google收购后发布的第一款手机;发布于2013年8月23日。型号为XT1058。
218 个问题 查看全部
How to fix crackling/popping sounds when playing music via Bluetooth?
The last few weeks my phone has not been able to play audio via Bluetooth to any speaker I try it with. Whenever I hit play loud popping and crackling sounds happen.
I was wondering if I needed to replace or fix any of the hardware or whether it would be software issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
Hi Oscar
First backup and then perform hard reset and see if it is software issue. If nothing change then you will know that is hardware issue.
Hope this help
这个答案有帮助吗?
得分 0
添加一条评论
It could be your wifi router interfering with your bt headphone.
这个答案有帮助吗?
得分 0
1条评论:
There are no wifi routers in car....it seems that cracking noise started ti appear with new ios 10.3.2. Ive been using same phone via bluetooth on several cars for long time and never noticef crackling until now with those recent apple updates. For one moment i thought its the brand new sound system in my cadi thats doing it. But when i switch to radio there is no crackling sound, so its not speakers pheww....
完成的
添加一条评论
After scouring the internet for answers to this very question I started messing around with my phone settings. Because like a lot of people nothing changed with my BT speakers. Not in my car, not my sound bar, or my headphones. The problem came from an update in iTunes. You need to go into “settings” and scroll down to “music” and turn OFF the “sound check”.
这个答案有帮助吗?
得分 0
添加一条评论
If you got an iPhone go settings then scroll down to music and tap EQ and check if you have it on bass booster if you don’t and it still sounds like that try putting it on late night, I worked for me.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
oscarpurtell 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 95
总计 20,029
