跳转到主内容
An Android 4.4.2 smartphone released November 1, 2014.
Why is my bluetooth playing in bursts
My Bluetooth connects to my speaker and plays spotify or music over it but it just plays in short fast bursts ive tried resetting the phone the bluetooth the speaker im at a loss for anything else to try.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Hi,
Are you playing the music 'off line'? If so try turning 'off' your phone's internet connection and the WiFi as well.
This will enable most of the phone's resources to go to the Bluetooth service. See if this improves the connection.
Go to Menu > Settings > Wireless and Networks > more > mobile networks > data connection. Select off. This setting only turns off your phone's data connection. The phone still works as a phone but you may not correctly receive multimedia sms' (mms ), ordinary text messages (sms) are OK and of course the internet does not work. Remember to turn the setting back to on when you want to use the internet or receive mms'.
To switch off the WiFi , go to Menu > Settings > Wireless and Networks > WiFi > swipe button left to off
If you are streaming music, then maybe you should check what other apps may be using the internet at the time and see if you can prevent them from doing so. Be careful not to turn off any system apps. If in doubt, don't.
Also, how far away from the phone is the Bluetooth speaker? Most of the common Bluetooth devices don't have a range beyond 10 metres (33 feet). Are you operating it within this range? If you are at the limit try reducing the distance between them. Also try it with the charger connected to the phone and on, just in case the phone's battery is performing below its' best.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
tylenall 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 130
