跳转到主内容
2.3L 4cyl or 3.0L V6, 6th Generation
426 个问题 查看全部
Sparks on my distributor cap/ Car wont start
A few days ago I drove through a pretty sizable puddle of water on the side of the road and my car suddenly shut off (while i was driving). 15 Min later, it started back up again no problem.
Yesterday, it rained all night and this morning my car wouldn't start. I hear the started turning so I know the battery is fine so i suspected I was not getting a spark. I then had a buddy turn the key while i was looking under the hood and every time he turned the key i saw a flickering spark on my distributor cap. I assume iv got a short in there due to humidity or water infiltration (its been raining/snowing for a couple days).
Any way to further trouble shoot it? Anything else I could check/ try before buying a new one and replacing it? What kind of additional damage could this have done to the other systems?
Any info helps
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Easy fix:
  • Obtain a can of WD-40 ;)
  • Pop off the distributor cap (it's usually held on with spring clamps)
  • Clean & remove excess moisture with a cloth or strong tissue paper, both inside and outside the cap
  • Spray a shot of WD-40 inside the cap
  • Refit the cap
  • Spray a light coat of WD-40 on outside of cap
This should get your car going again.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
marc 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 1,396
