跳转到主内容
加入维修社区 - 创建账户
Repair guides and troubleshooting for the Acer Aspire 5, a series of laptops on the Windows OS by Acer.
Laptop won't boot up
Hi, I have a problem with my Acer Aspire V5-561
Lately I'm having a lot of trouble getting it to start. I am thinking HDD problem but please let me know if you have another idea of what it might be. Here goes the story:
- Laptop was working fine all day. Close it and go back home. When I arrive home i push the power button. Everything starts: LED for power, battery and HDD start but after a few seconds HDD light start to flash faintly. It stays like this for a long time before I get angry and I force shut down. I then famous unplug power and battery and press on power button for a minute. I let the laptop be for a few minutes and then try again. It opens up without a problem and use it all evening before closing it.
- The next day, same problem occurs. In the morning I try to open it but nothing happens for 20min. I force shut down and then do the same procedure: unplug power, battery and press power button. I then go to school and let the laptop home. When i come back in the evening I power up the laptop and everything works fine! I run a quick check of the HDD with a program from Acer and it tells me that it passed the test (i didn't do the extensive test). So I close it to test if it has changed and... here i am, laptop won't start.
TLDR: Laptop seems to only start after I unplug power and battery and press the power button for a minute. If i close it again, it won't work (LED power+battery is fine but HDD flashes). Thinking HDD problem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Your issue does resemble a Hard drive failure the best way to tell is to run a hard disc scan. If you download and run this program it can tell you how much life is left in the hard drive and give you a better understanding of what you should be pursuing , whether it is replacing the hard drive or something else.
http://www.hdsentinel.com/ you can download the free version for what you need it for
Hope this helps.
这个答案有帮助吗?
得分 2
添加一条评论
look friend maybe the battery of bios need replace and anther thing you need new windows and after you install widows go to power option and make the chose (when i close screen )make it do not doing thing.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Frank 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 29
总计 6,559
