跳转到主内容
问题已关闭
GB Micro blank/black screen
So, I found my GB Micro recently and found that it doesn't work. I've fully charged the device and get the same result whether its plugged in or not.
Upon turning the device on, the Select and Start buttons will turn blue for 2-seconds and then quickly blink (still blue) three times and 3-seconds following that, the Select/Start led turn off. During this, the back-light comes on, but the display is black. I've already tried replacing the battery.
Video here: https://www.youtube.com/watch?v=RC6EgFjl....
Anyone here have ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
its probably because you havent used it in a while or it is worn out i would suggest take it to get it looked at.
这个答案有帮助吗?
得分 0
1条评论:
No idea where I would take it. Usually when something stops working, you should be able to find and replace that non-working part to get everything up and running.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 276
