跳转到主内容
Released in 2010, the HP Deskjet 1055 is an all-in-one printer, scanner, and copier.
Paper feed malfunctions, does not take in paper
When try to print, the paper will not go into the copier
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I have this issue too, jams on side
完成的
添加一条评论
1个答案
已选择的解决方案
It looks like the belt for the rollers that feed the paper is broken. Does it make any noise when it tries to pick up the paper.
这个答案有帮助吗?
得分 1
4条评论:
sound seems normal I think
完成的
How do I get into it to fix such a problem. Someone pulled paper out of the feeder on top (back) and seems to have disturbed something. Forrest
完成的
There is a sensor or engaged button to let the printer know the top is closed bypass that sensor/button and have the printer top open and start to look at the rollers and watch for anything that looks abnormal. Also if you wanted to open it complete start to look for screws and tabs to pull the casing and frame apart.
完成的
Do not use alcohol to clean the feed tires, soap is the best (409) soap will not dry up your feed tires..
http://copierservicemn.com/
完成的
添加一条评论
添加你的答案
forrest speras 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 617
