跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
I can not call with my phone?
I can call people and I can hear them speaking but when I try and talk there is a lot of static and they can barley hear my voice. I try to talk to Siri but she cannot understand anything?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Sounds like your microphone might be bad. Try the voice recorder app on the phone and see if it's clear. Check the microphone area too and see if there's any dust clogged.
这个答案有帮助吗?
得分 1
2条评论:
I cleaned out the microphone area but didn't fix anything and when I use the voice recorder app all I hear is static
完成的
It might need to be replaced then. But before doing so, try a pair of apple earphones and use the mic on that. If it works, then you might need to replace the microphone in the phone.
完成的
添加一条评论
I had a problem when the lag call recorder. I set another application to record and everything was working
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ak007 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 52
