Why won't my sanding pad stick?
The sander pad is not sticking during normal household use of the DeWalt D26451
Orbital sanding pads won't stick if debris or tears in material are present. To replace the hook and loop / Velcro pad: Simply remove the three screws on bottom of sander to replace pad. Here is a link to a replacement pad.
这个答案有帮助吗?
Apparently everyone one else is just experiencing worn out sanders or sandpaper disc’s.
I just took my brand new Hyper Tough 2.4 Random Orbit Sander out of the box this morning. I also purchased 2 boxes of discs.
I used it on and off for about 45 minutes before it started throwing the disc off. The disc I was using wasn’t even used up yet. But I still put another new one on. They only hold about 15 minutes worth of sanding before falling off.
Obviously these things are defective in their design. I’m very disappointed.
After experimenting it is not the attached sander pad that is the issue but the sanding discs that won’t stick on firmly.
Now I’ll have to remake my discs by glueing on my own loop and disc tape.
The sander I have is the Hyper Tough 2.4 Random Orbit Sander ( it came with 2 discs that have the same problem)
The two extra boxes of 5” Hook and Loop Sanding Discs are made by Gator Power.
这个答案有帮助吗?
I solved my issue very easily. I had a package of Velcro in my sewing basket. Took the fuzzy part and used some E6000 glue I had on hand. I cut 4 I” pieces and glued the on my fly away discs. I only waited 30 minutes for it to dry since I was in a hurry, and I was back in business. EZ
I bought a brand new 3M polishing pad today and the same thing happened. I was so upset as the 3000 grit pad cost me $9.00 and was flying off after 15 minutes. My orbital sander pad is in mint condition so I knew it wasn't that. Also all my other pads stuck just fine. Thank you for the tip. I was gonna bring it back but that grit is hard to find in the city I live in.
I have replaced the pads twice and still the paper flies off. It's still brand new pad and paper- no dust or debris.
I shouldn't have to put in new hook and loop- therefore not giving it a perfectly flat surface. I shouldn't have to glue on pads... this is ridiculous, and it's a garbage product.
I used to only buy Dewalt, but it has gotten so cheap that I will never buy Dewalt again.
I bought a new Dewalt DWE6421K and used it maybe 2 hours and it does the same thing. Completely unacceptable. I have a Bosch that I've had for years that has never done this. Thanks for the tip, but I'm with Cathy I shouldn't have to do this workaround on a new sander at all.
If you press down hard on the sander it creates too much heat and it burns off the velcro on the pads. You can't see the burned melted velcro but it's there.
I don't know if your refering to the sanding disks or not but I am going on experience here that the sanding pad which is screwed on the tool that allows you to put hook and loop sanding disks on it. If your not able to but sanding disks on the pad then your sanding pad is worn and can be replaced for $20 which I am getting pretty close to having to replace mine but I had my sander for quite awhile and never had a problem like that. It's just my sanding pad is tearing on the upper part now to replace it I will have to get back to you on that. I heard it's really simple by taking the screws that is in the sanding pad out and then it comes right off i just have not done it myself. Finding the part is easy go to Dewalt.com then hit what country after that, go to parts and information tab now from there you will find what you need on the second coumn on the right hand side in the small print you will find where to find parts by clicking on the find parts on service net.
这个答案有帮助吗?
Sanding pad is not the issue. I’ve got a brand new one and paper flies off as soon as 1-3 minutes into sanding. Wasting a lot of paper that isn’t cheap.
Wanda... same here. You can easily replace the pads- I got mine at Home Depot. But I've had the same issue with the two new ones that I purchased and they failed to work. Not buying Dewalt again
Harbor Freight - buy a new cheapo sander. Cut your old pads to fit.
OR- Find a auto-paint-body-shop supply store. They cater to all bodyshops, ask your local bodyman.
Buy common paper-backed discs of whatever grit desired. This ain't HomeDepot, so don't ask for 'medium'.
Buy a small amount of Disc-Adhesive. Maybe a tube, or can/w/brush.
Remove the hook pad from your sander. I used a blow-dryer. Zipped right away.
Paint on the adhesive, let dry, several coats, nice glossy surface.
Paint the disc with very-light-and-thin coat, let dry, slap on.
If you really want to be a pro, buy the pre-glued discs with peel-off wax-paper backing.
They don't smell like glue.
My 25yr old Black&D JitterBug, and my MonkeyWard orbital, are both converted.
The JitterBug cushions had hardened with age. I cut a old mouse-pad rubber, epoxy over the old pads.
这个答案有帮助吗?
I've been using a Dewalt Orbital sander for years. I go through them at a pace of about 1 every 9 months. I have additional replacement pads when they wear out. I've tried 3 new ones in the past two months and the sanding discs just won't stay on. Today I'm going out to purchase a Makita. Hopefully I'll have better luck. Btw, it's not the sanding pads since I've tried 3 different grits and none will stick for more than a few minutes. Dewalt must be making crap replacement pads.
Don't buy the variable-speed model. Ho-Lo speed switch is fine.
That VSR-drill-trigger will tire you out.
You're gonna like the professional tools at the body-shop-supply !
Take your credit card !
All I can get is Diablo sand paper. It won’t stick either. So frustrating!
I agree that something seems to be up with the DeWalt sanding pad. My original lasted 15 years. When the discs starting flying off, I got a new DeWalt replacement. It took 15 minutes before the discs flew off the new pad, and I was not pressing down on the sander or holding it in one place which I've been told melts the hooks on the velcro. The dust catcher was clean, the sander was clean, etc. I will say the "hooks" on the replacement sanding pad felt very shallow new out of the box. The velcro on my clothing works better. Quite DISAPPOINTING!
I have a Ryobi PSA that I never have trouble with. I just picked a Makita and replaced the PSA backing pad with a new one. The new one will not hold discs. I get about 5 minutes of sanding and then the disc is off across the room. The Ryobi seems to have a much firmer backing pad than the Makita and I wonder if there is too much flex in the Makita backing pad which might be causing failure in the glue. The Makita pad also has little bumps on it while the Ryobi is completely flat. The Makita is running at 12000 rpm while the Ryobi runs at 11000. With the problem I am having I am thinking of sanding off the bumps on the Makita and maybe running it through a rheostat to slow it down a bit. Another thing I might try is to find a thin rigid backing pad and gluing it to the makita pad to provide a firmer surface.
这个答案有帮助吗?
I have used random orbital sanders for many years. The hook and loop connection to a sanding disc will certainly fail if either or both of the following 2 cases occur.
So any solution will include fixing the sanding disc to sanding pad bond. That requires either a replacement pad or being creative as others have suggested here - like using 1” velcro squares and gluing them to the sanding pad. I am all for extending the life of the original pad for as long as possible but to get optimal life out of your sander, you’ll need to keep the trap clean, blow out the sander and pad before and after you use it, and not push incredibly hard when you sand. Best of luck to you!
这个答案有帮助吗?
过去 24 小时: 4
过去 7 天: 33
过去 30 天: 154
总计 86,291
3条评论
Forget a new backing pad unless it is damaged. Get a spray can of 3M adhesive. Happy sanding!
由 jwebersweb 完成的
Do you let the glue dry
由 David mc ivor 完成的
Doesn't work unless you want to glue sandpaper to base of sander
由 David mc ivor 完成的
