跳转到主内容
Step-by-step guides for handheld, stick, canister, robotic, and upright vacuum cleaner repair.
1551 个问题 查看全部
Canister vacuum no suction when brush attached Bosch
1450W 12 amp vacuum
BSG81396UC Premium Prestige Canister Vacuum Cleaner
I was hoping you have advise my vacuum works fine suction etc until
I plug in the hose with peered brush attachment Then there is no suction at all . Hose, filter , and bag are clean and free of clogs
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
Well you either have a clog you don't know about or you aren't switching the suction to the hose. Take off where hose starts and see, if you have suction there then you know it's the hose. And if you don't have suction then it's somewhere else. Pretty simple
这个答案有帮助吗?
得分 0
添加一条评论
After checking proper suction by removing the hose, inspect the brush for potential obstructions like hair or debris. Remove the brush cover for a closer look. Additionally, run your hand along the hose to check for punctures or leaks, which can significantly reduce suction. Certain models feature adjustable brush heights for various floor types. Confirm that the brush height suits the cleaning surface, as an incorrect setting can impact suction.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
DPWCT 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 113
