跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Earpiece,receiver not working on iPhone :/
My ear speaker stop working after I decide to get replace apple logo for led up one.I damage the battery flex cable but I did replace it with new battery,right now my only problem ear speaker not working.I can't hear anyone who is call me,only on speaker or with headphones I could hear.I don't know where is possibility to damage ear speaker just to replace the battery and apple logo,maybe some how I did damage flex cable that's connect to ear speaker (reciver) but I don't know which one,guys help figure it out what I need to replace.I don't think there is problem with earpiece.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Hi Daniiel
Most likely won't be the actual earpiece, they don't brake to easy. I will assume that you have damage the proximity cable, so change this one and see if it is going to work.
Hope this help
这个答案有帮助吗?
得分 1
添加一条评论
Yes seems like,it's flex cable which is for front camera and censor as well.Will replace and hope it will gonna work :)
这个答案有帮助吗?
得分 0
3条评论:
Good luck hope it will work after the replacement. Please if it works mark my answer as chosen solution. Thanks
完成的
I have the same issue actually. Did replacing that flex cable fix the problem? I also changed the led light mod and I believe it shorts out the front facing camera flex cable causing both the camera and ear piece to stop working
完成的
Yes it did fix the problem.I actually damage this flex cable again and that time my front,back camera and flashlight and earpiece stop worked but I did replace it again and everything back to normal.It very important to be careful with that flex cable when u open up IPhone :)
完成的
添加一条评论
添加你的答案
Daniiel Tsykhorskyi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 10
总计 1,374
