跳转到主内容
Announced on October 16, 2014, the iPad Air 2 is a thinner successor to the iPad Air.
Tip of Lightningcable broken and stuck in the Ipad...
Worst case cenario? While loading my Ipad Air 2 it fell from the desk directly on the lightningconnector with the cable in it. The tip of the cable broke and is now stuck in the lightningconnector - so far no way of getting it out, even the repair shop didnt manage.
If they open it and try to repair/exchange the lightningsocket (or whatever its called) apple warranty is void. (Ipad is just about 2 month old)
Now on the other hand apple probably wont repair but just offre an replacement for unbelievable 380 €!!!! 380 € because a loading cable broke!!!! And apple build this thing in a way thats a) hypersensitive and b) refuse to repair it!
I really hope anybody here has got a better idea?
thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
You may want to try another repair shop. So far, I have always been able to remove broken lightning tips. I use a microscope and dental probes, and it works great.
这个答案有帮助吗?
得分 2
添加一条评论
Could you post a picture please?
这个答案有帮助吗?
得分 1
添加一条评论
Dear David, Dear Chris
thanks for your quick replys.
here is the best picture I could take so far:
the aluminium shell is bend upwards, the socket itself seems ok, but can´t say for sure.
David, I thought about using a very fine drill to either break the lightningcable tip to pieces that I can get out with a fine brush or vaccumcleaner or - better - have the drill stuck in the tip so I can pull it out?
otherwise i thought about using several small plastic pipes and inject a strong glue through them, so I can glue them to the tip and pull it out? otherwise I might try with a shop that´s repairing clocks or other fine mechanics?
thanks for your help!
best
benjamin
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
caspar georg 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 176
