跳转到主内容
The Acer Extensa 2509 features an Intel Celeron N2930 processor with Intel HD Graphics.
9 个问题 查看全部
Why is my cousins laptop screen turned white?
Me and my cousin has been trying to fix a Acer laptop. Every time we turned on the laptop screen is always on white and lines down on the left side of the screen. We removed the battery and hold down the turn on button more than 60 seconds. We tried shutting it down but it doesn't work at all.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
If the screen is turning on the lighting is ok. So it is an image signal issue.
You should check the flat cable on the back of the screen, to ensure that is seated properly.
But when I read twice your description I have noticed you mention some lines in a corner of the screen, so the problem is related to the t-con of the screen.
The easiest fix is to replace the screen (same size and technology).
Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jade Harrison 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 77
