跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
Cracked screen replacement doesn't come with home button
I ordered a screen replacement. The guide doesn't not reference the home button, so one would assume that the new part would have one. It doesn't.
iPad Air WIFI版 前面板替换
It is possible to move the home button to the new part? If so, where is that documentation and why is it not mentioned in the guide above?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
You must transfer the home button, flex, and bracket over to the new digitizer. I've never seen one come with these items included.
这个答案有帮助吗?
得分 0
添加一条评论
Depending where you buy the screen it may or may not have the home button installed. The screens I purchase come with the home button but I always remove those and transfer the original home button. When I do a iPad repair I always try to move all the original parts that I can in any repair. If your doing this repair make sure to take pictures of the home button ribbon and how it loops around and hooks into the motherboard. If you don't you will forget how that home button cable ran to the motherboard.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
damonbrandt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 84
