跳转到主内容
A 6" random orbital sander/polisher that was manufactured by Bosch in 2003. Repairs may require basic everyday tools.
6 个问题 查看全部
When do I need to replace the sanding pad?
How can I tell that it is time to replace the sanding pad?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
An easy way to tell if the sanding pad needs replacing is to see if the sanding pad feels smooth. If it does, the sanding pad has lost it's grit and needs replacing.
这个答案有帮助吗?
得分 0
添加一条评论
Three things:
- When you start getting swirl marks.
- When it feels like substantially more effort is required to do routine tasks.
- When it stops wanting to stick.
PS...Did you mean Sanding Disc?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Roope Virtanen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 375
