跳转到主内容
于 2014 年 10 月 16 日发布,型号为 A1347 和 EMC 2840。
198 个问题 查看全部
part numbers for drive mount/bracket and drive cable
Can someone tell me the part numbers for the drive mount or bracket and the drive cable are?
I am planning on purchasing a 2014 mini with only a flash drive and then I want to add a second conventional drive. I don't want the fusion drive that they offer.
Thanks much
john
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Smart move! Getting the SSD model is the way to go here.
Yes, you can add in a standard 2.5" 9.5 mm high SATA drive. Follow the steps in this IFIXIT guide: Mac Mini Late 2014 Hard Drive Replacement.
You'll also need the ribbon cable, mounting screws, grommets & special tool from the 2012 dual drive kit: Mac Mini Dual Drive Kit.
Mac mini Dual Drive Kit图片
产品
$26.99
这个答案有帮助吗?
得分 2
5条评论:
the situation I am referring to is if I don't get a drive and just the flash ssd. Somewhere along the line someone told me that if I get only the flash drive there is no bracket for a hard drive so it really isn't replacing the drive it is adding one. So I would need the bracket which a think comes with the cable.
thanks
john
完成的
No bracket needed! Apple designed things so you only need the screws, grommets & cable. All are present in the kit. All you'll need to add in is the drive.
完成的
does the cable from the 2012 kit work for the 2014 mini?
完成的
Yes, Apple didn't change it.
完成的
thank you for your help
完成的
添加一条评论
添加你的答案
john prokopek 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 222
