跳转到主内容
型号A1040 / 10, 15, 20, 30, 或 40 GB 硬盘/ 中央转盘上方有四个触控激活 LED 背光按键
97 个问题 查看全部
Cannot get cover open and damaged large too in the process
I tried to open the case on my iPod G3 to replace the battery. I could not get the case open and damaged the large tool in the process. (The sharp edge is completely ruined!) The small tool appears to be useful but is also showing signs of wear. Is there another tool that could be used or could I get a replacement. I know the instructions said it would be difficult, but it was more difficult than I expected.
Billy Blanchard
Thousand Oaks, Ca.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
I have this ipod, and I actually opened mine with a razor blade, then I wedged a thin knife in there once I got it open enough. Then I slid it carefully around the edges until it finally came open. You are right, it is harder than they make it seem. It took me about ten minutes or so to do carefully as to not break anything. Good luck!
这个答案有帮助吗?
得分 1
添加一条评论
i used a torch lighter and heated up the metal edges to soften the adhesive, then improvised tools for the job.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
b34blanchard 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 1,311
