跳转到主内容
iPad Mini 4 发布于2015年9月9日,有着类似 iPad Air 2 的性能和更小巧的身材。
176 个问题 查看全部
Will replacement glass and digitizer work on the Ipad Mini 4?
My son broke his Ipad mini pretty badly. I have the heat gun to remove the glass. I want to order new glass. But the ipad 4 is way more expensive than the other 1,2,3 models. What model and digitizer can I use?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
The reason the iPad mini 4 is more expensive is because the digitizer/touch screen are glued to the LCD, so you have to replace both, making for expensive repair. Doing a glass only repair on the iPad mini 4 would be near impossible without the expensive and high tech tools. The iPad mini 1,2,3 the digitizer and LCD are not glued together so if the screen is broken you can just replace the digitizer/glass.
这个答案有帮助吗?
得分 2
2条评论:
Hi. there, I have an Ipad Mini 2 the Screen is cracked. do I have to replace the LCD and Digitizer ? can you please explain why. Thank you!
完成的
Just the glass only in the iPad mini 1/2/3 much cheaper repair.
The 4 has a glue between the entire lcd and touch digitizer so you cannot split it apart like the 1/2/3 models.
完成的
添加一条评论
From what i understand
you want to use another glass/ digitiser from iPad mini 1,2or 3 on and iPad mini 4
if this is correct you can not use any other glass/ digitiser on iPad 4 other than what was intended sadly
这个答案有帮助吗?
得分 0
4条评论:
also if you don't mind me asking how much is a new digitiser
完成的
New digitizer is around $220
完成的
now i know this is more expensive but you get a new iPad?
https://www.apple.com/support/ipad/repai...
完成的
I don't think the ipad you get is new; I believe it is refurbished with a 90-day warranty. However, it may indeed be the best option.
完成的
添加一条评论
Hi I had tried to separate the glass and the LCD and and punctured it. Now not working. Can i buy a new LCD to replace? How much is it? Will I need to keep any part from my old LCD for use. This is a mini apple ipad 4
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jenny Minerva 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 12
总计 9,937
