跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 个问题 查看全部
Is my battery the problem?
Hi guys,
I have a Macbook Pro Retina, which yesterday stopped working when operating on battery alone and requires the power at all times. I have had it for 2.5 years.
It won't switch on immediately, however, with the power adapter. I have to hold the power button for 8 seconds, then attach the adapter. It then fires up, with the fan going crazy.
If the adapter comes out, it immediately goes dead.
When I go to check the battery diagnostics in the power section of the system overview, it's not even acknowledging there is a battery and shows no information at all.
My question is, while I obviously need a new battery, do you think there's more to it than just that?
Thanks,
Betty
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
First I would do a SMC reset to make sure the SMC is working properly. Follow this Apple T/N: Resetting the System Management Controller (SMC) on your Mac.
You could also give this little gem a try: coconutBattery it's a free app that I think does a better job in showing how things are doing.
Then tell us if the SMC is reporting the battery now. If not the charging control logic (SMC) has problems and you still may need a new battery as well. But you'll need to get the main logic board repaired first.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sarah Betty Andrews 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 97
